Import/Export Email Templates
Organization email templates and System email templates have been improved by Docentric.
The table below lists the data entities provided for Organization email templates. For the Import/Export scenarios use the first two data entities. For Copy to Legal Entity scenario use the first and third data entity.
| Data entity | AOT name |
| Docentric organization email templates | DocSysEmailTableEntity |
| Docentric organization email messages package | DocSysEmailMessageTablePackageEntity |
| Docentric organization email messages | DocSysEmailMessageTableEntity |
The table below lists the data entities provided for System email templates. For the Import/Export scenarios use the first two data entities. For Copy to Legal Entity scenario use the first and third data entity.
If you're using Docentric improved collections process automation emailing, you can use the Docentric email template sending settings entity (available from Docentric v3.5.0) to import/export the relevant settings for Docentric email action types (these settings are global, so you don't need to copy them between legal entities).
| Docentric system email templates | DocSysEmailSystemTableEntity |
| Docentric system email messages package | DocSysEmailMessageSystemTablePackageEntity |
| Docentric system email messages | DocSysEmailMessageSystemTableEntity |
| Docentric email template sending settings | DocCustAutomationSysEmailSystemTableEntity |
Why the "package" data entities?
Email templates may contain Email messages larger than 32768 characters. Due to a known and documented SQL Server Integration Services limitation, strings longer than 32K will be truncated during the import. The solution is to export the string fields with potentially large content (such as Email message body) into external files and generate the package with all resources during the export.
Learn more about "package" data entities and import/export process >>
Copy to Legal Entity copies the data internally, therefore there won't be any truncation and you can use the messages data entity without package suffix.
Below are instructions for Export, Import and Copy to Legal Entity on the example of Organization email templates. Exactly the same steps are applicable to the System email templates.
Export
In the Data management workspace create a new Export data project with Docentric system email templates and Docentric system email messages package data entities as shown below. Select the XML-Element Source data format for both data entities. Make sure to switch the Generate data package flag ON.
Start the export (Export now or Export in batch). When you see in the Execution summary form that the export is finished, click the Download package menu item. You will get a ZIP file with the exported content, which you will use for the Import.
Import
In the Data management workspace create a new Import data project. Select Add file and click the Upload and add button:
A dialog will open. Point to the ZIP file downloaded at the end of the Export process. The information about the data entities will be loaded from the ZIP and displayed in several info and warning messages. You might get the warning messages about some missing fields in the staging table as in the image below, but you can ignore them, because these fields actually exist and will be correctly used during the import.
You should get the following Selected entities:
Import the data by clicking one of the Import menu items.
In the Data management workspace create a new Copy into legal entity data project with Docentric system email templates and Docentric system email messages data entities as shown below.
Specify the target legal entities (USPI in the example above) and click the Copy into legal entity menu item.
Copy to Legal Entity via Package
As explained earlier, when copying between the legal entities, data is copied internally, therefore even the long Email messages shouldn’t be truncated. But if you encounter problems with the truncated data, then you need to use the Docentric system email messages package data entity instead of the Docentric system email messages data entity.
In the Data management workspace create a new Copy into legal entity data project with Docentric system email templates and Docentric system email messages package data entities. Select the source legal entity and target legal entities, then click the Copy into legal entity menu item.
Import/Export Print Management Settings >>
Import/Export User-Defined Labels >>
How to Use Deployment Tools >>
