Output File Formats
With Docentric, you can generate reports with Docentric Report Generator or SSRS Reporting Services and distribute them using improved Docentric print destinations, which means improved emailing, distributing, printing and archiving.
Most of the emailing, distributing, printing and archiving features are part of Free Edition. Learn more >>
Which output file formats are supported depends on whether Docentric Report Generator or SSRS Reporting Services is used for document generation.
Output file formats supported by Docentric
- Microsoft Word
- TIFF
- XML
- EMF
These output formats are supported for reports generated by Docentric Report Generator from Docentric Word-based templates (templates which are Word documents). On our roadmap is to support Excel output format for reports generated from Docentric Excel-based templates (templates which are Excel documents).
EMF file format is used for printing reports to physical (network) printers, via DRA (Document Routing Agent) in cloud environments or directly in on-premises environments.
Output file formats supported by SSRS
On the other hand, when generating reports using SSRS Reporting Services and distributing them via Docentric print destinations, supported output file formats are those supported by SSRS Reporting Services when distributing reports via SSRS print destinations. These are:
- CSV
- Microsoft Excel
- HTML4.0
- Image (TIFF)
- MHTML
- XML
- Word (.doc)
- EMF
PDF/A Standard Support
With Docentric version 3.4.6, generating PDF documents which are PDF/A-compliant is supported by both Docentric Generator and SSRS Reporting Services (when printed using Docentric print destinations). Learn more >>
Learn About Docentric and PDF/A Compliance >>
PDF Security: PDF Signing and Encryption >>
Improved Docentric print destinations >>
