Import/Export Report Restricted Printers
Import/Export through Data management framework
We provide the Docentric Report Restricted Printers data entity to support the import/export of Docentric Report restricted printers through the Data management framework.
Update through Excel Add-in
You can update Report restricted printers by using the Excel Add-in, which is accessible from the Set up by printer form:
If you use the Excel Add-in not only for updating the existing entries, but also for adding new entries, you might find useful some hints we wrote about the Docentric User Defined Labels data entity.
Report Restricted Printers >>
User Allowed Printers >>
User Default Printer >>
