Enablement, Demo Environment & Training
For partners: before you deliver Docentric on a client project, get your own team fluent and build an internal environment you can learn and demo in. This page is the learning journey, while the client-delivery journey is covered separately in the Implementation methodology.
The good news for teams new to Docentric: most of this you can do on your own, in your own environment, using the replicas and tutorials below. You do not need a live client project to become competent.
Recommended enablement path
We recommend working through the following order. Each step builds on the previous one and can be done in an internal development or sandbox environment.
- Understand the architecture: Read the Docentric AX architecture overview so you know how Docentric sits on top of the standard D365FO reporting pipeline. See also How Docentric fits the D365FO reporting pipeline on the guide's main page.
- Install Docentric and prove the loop: Install the core models and the Designer (prerequisites are in Before You Start - Prerequisites and environment compatibility), then run the Start here: your first hour steps from the main page: install, register, preview a Purchase order confirmation, change a title color, re-preview, add one data field, re-preview.
- Complete the basic setup tutorials: Follow the Basic setup video series and the how-to manuals (links below) to get comfortable with template modification, report setup, parameters, and template storage.
- Customize one Docentric SSRS replica: Take a replica template into the Docentric AX Designer and make real layout and data-binding changes, then apply and preview it.
- Add data through a DSP class: Have a developer extend a DSP class to add fields or a custom placeholder, regenerate the DDSP file, and add the new data to the template. This is the core technical pattern you will reuse.
- Configure one email distribution scenario: Set up a Docentric Email print destination, with a dynamic subject/body and an attachment.
- Set up archiving or SharePoint scenario: Save a generated document to an archive, SharePoint, or Azure Blob storage.
- Practice moving setup between environments: Export and import report setup, as well as Print management settings, and copy the templates, so you understand promotion from DEV to TEST/UAT to PROD before you do it on a client project.
After working through these, your team should be ready to take on a first implementation. Docentric support is available through your partnership.
Build an internal demo and training environment
A dedicated internal environment gives your team a safe place to learn the implementation pattern they will repeat on client projects, and doubles as a demo environment. The goal is not to showcase every Docentric feature, it is to cover the patterns that come up on real projects.
A good demo/training environment includes:
- Docentric AX installed, with a partner license loaded.
- The Docentric AX Designer installed on the machines used for template design.
- Sample legal entities and demo data.
- At least one implemented Purchase order confirmation.
- At least one implemented Sales invoice.
- One custom template variation (for example, a branded version of a replica).
- One email distribution scenario.
- One archiving or SharePoint saving scenario.
- One example with additional data added through a DSP class.
- One example with multiple templates for a single report.
- One example of Print management setup (original vs copy, or a conditional setting).
Build this once and keep it. It becomes your reusable baseline for onboarding new team members and for client demos.
Sample templates, demo data, and reusable scenarios
You do not start from a blank page. Several reusable assets are available:
- Docentric replicas are your ready-made templates. The Docentric AX SSRS Replicas model ships replica templates and DSP classes for a large set (around 80) of standard reports, and the Docentric AX CBD Replicas model adds replicas for most common CBD ER formats. For common reports you customize an existing replica rather than design from scratch.
- Standard D365FO demo data works well for practice and demos. The standard demo legal entities and data that ship with D365FO development environments are enough to generate realistic documents while you learn.
- Your internal environment is your accelerator. The scenarios you cover in previous step (branded template, email, archive, DSP extension, multiple templates, Print management) become the reusable starting points your team applies on client projects.
- Partner-specific materials: Additional partner accelerators, curated demo assets, and reference materials are provided through the Docentric partner resource center, arranged as part of your partnership onboarding.
Training and materials for consultants
Train your team members in at least two groups, matching the two core roles responsible for delivering a Docentric implementation.
Functional consultants and key users should attend the Docentric Basic training and the Docentric Advanced functional training (or receive equivalent internal training). They should be able to:
- configure reports and understand where templates are stored,
- preview and test documents from the business process,
- generate DDSP files,
- maintain Print management and understand how it affects output,
- maintain templates through their lifecycle,
- recognize whether an issue is in standard D365FO or in Docentric, and whether it is a setup, data, template, or code problem.
Technical consultants and developers should attend the Docentric Technical training (or receive equivalent internal training). They should understand:
- the Docentric architecture,
- report registration and DDSP generation,
- DSP classes and how to add or reshape data,
- deployment of system templates,
- troubleshooting and diagnostics.
Self-serve resources
These are freely available and are the fastest way to make progress alone:
- How-to manuals — the reference documentation for setup, template design, print destinations, and Print management.
- Video tutorial playlists on the Docentric YouTube channel: Template designer, Basic setup, and Advanced functional training.
- Architecture overview — recommended before the technical training.
- Blog and forum — practical examples, including DSP class patterns, and a place to ask questions.
We also run scheduled live Basic and Technical training sessions. We recommend registering your consultants for one of the upcoming training slots early in your onboarding.
Implementation Guide (top-level) >>
Before You Start >>
Implementation Methodology >>
