Improved Email Processing
Docentric improves Email processing in various ways:
- Supports emailing reports using Batch email sending status
- Reenables emailing alerts using Batch email sending status
(Workflow and Retail emails are supported OOTB) - Improves Batch email sending status
- Improves Email distributor batch
- Enables Email distributor cleanup
- Supports emailing Collections process automation reminders using Batch email sending status
Learn more >>
Improved Batch email sending status
- Added email message fields such as Cc, Bcc, Reply-to, Bounce-to, Read receipt address, etc.
- Added metadata fields such as Context information, Account number, Document ID, etc.
- Better view of a single outgoing email message including added message fields.
- Update all fields of a single outgoing email message its body and attachments.
- Updating particular fields of multiple outgoing emails at once.
- Download an outgoing email message as EML file, which you can open with an email client, e.g. MS Outlook.
Open Batch email sending status from Customer and Vendor cards
By clicking the Batch email sending status button in the General tab > Outgoing documents on the All customers or All vendors form, which is added by Docentric, you will see the list of all outgoing emails with generated reports for the selected customer, i.e. vendor.
Improved Email distributor batch
To support Cc, Bcc and Reply-to and other new email message fields Docentric extended the existing Email distributor batch and called it Docentric email distributor batch.
Learn how to turn on Docentric Email distributor batch >>
From version 3.4.1, Records to include is added to the Email distributor batch dialog so multiple Email distributor batch jobs can be started for different outgoing emails. Learn more >>
Better error logging of the email messages sent via Docentric Email distributor batch is introduced. Learn more >>
Email distributor cleanup is a new operation introduced in 3.4.1 which deletes the Batch email sending status records selected via the same dynamic filter (Records to include) as for Docentric email distributor batch and additional parameters including Status and Created- and Last status change- date and time. Learn more >>
In version 3.4.8, for the input parameters Created date and time and Latest status change date time, the Relative data range type is added as an option, by utilizing the built-in setup General ledger > Ledger setup > Date intervals. This enables users to choose, in addition to the fixed From and To date time range values, a relative date range.
For example, to schedule a recurring batch job that deletes all emails (i.e. the records from Batch email sending status) sent in the last month every time it runs, configure the Last month date interval for Latest status change date time (by using Relative data range) and select Sent for Status on the Email distributor cleanup job dialog.
Improved Email Templates >>
Improved Alert Emails >>
Emailing reports using Email distributor batch >>
Improved Batch email sending status >>
Improved Email distributor batch >>
Troubleshooting techniques for solving emailing issues in D365FO >>
Improved Collections Process Automation Emailing >>
