Import/Export Electronic Signature Appearances
We provide 2 data entities to support import/export of Electronic signature appearances through the Data Management framework. These are:
- Docentric Electronic signature appearance groups,
- Docentric Electronic signature appearance.
Data entities need to be used in the same order as listed above, because Electronic signature appearances depend on Electronic signature appearance groups.
For migrating the signatures between D365FO instances, export the data as package and specify the XML-Element data format.
The whole process is described and documented with the screenshots in the Import/Export Container Data Fields Using D365FO Data Management article (look for the Import/Export the package chapter).
How to Set Up and Use Electronic Signatures >>
How to Use Deployment Tools >>
