Installation via Deployable Package
Docentric AX can be deployed using the following deployment options:
- Model files,
- Deployable package.
Apply Docentric AX deployable package
Docentric AX deployable package contains complete Docentric AX reporting solution for Microsoft Dynamics 365 for Finance and Operations. It has no dependencies or external services to install. Docentric AX will become fully functional immediately after you have successfully installed Docentric AX deployable package.
There are two ways to apply a deployable package on a D365FO system:
- Manual installation,
- By using LCS (Lifecycle Services).
1. Manual installation of Docentric AX deployable package
While a deployable package is mostly applied using Dynamics Lifecycle Services (LCS), you can also use the command line to manually achieve the same.
To manually install Docentric AX deployable package, follow the steps described in this article:
Manually apply a deployable package to a D365 for Finance and Operations environment.
2. Docentric AX deployable package installation using LCS
In order to install Docentric AX deployable package using LCS, you need to take the procedure described in this article:
Apply a deployable package to a D365 for Finance and Operations environment.
Apply Docentric AX deployable package on UDE
To be able to install Docentric AX deployable package on a UDE (Unified Developer Expierience) environment, you first need to convert LCS package to the new unified format. This can be done by using ModelUtil.exe from within Windows PowerShell. Afterwards, you can upload/deploy them to the UDE environment.
How to Unlock the Product >>
How to Install Docentric AX Designer >>
How to Set Up Docentric AX >>
How to Install Docentric AX via Models >>
