How to Install Docentric AX Designer
Clean Install
To install Docentric AX Designer for the first time run DocentricDesignerSetup_ver.exe and complete the installation process by following the setup wizard steps.
Upgrade
To install an updated version of Docentric AX Designer run DocentricDesignerSetup_ver.exe and complete the installation process by following the setup wizard steps.
Docentric AX Template Designer is Microsoft Word with the installed Docentric Add-In for Microsoft Word.
Technical requirements: Microsoft Word (desktop) 2013 or higher installed on a Windows 10 or 11 machine.
The latest version or a hotfix you can find in Docentric Download Center.
Before installation check the version of Docentric AX Designer you have currently installed. You can read the version in the File ribbon tab in MS Word by clicking the About Docentric button.
How to Set Up Docentric AX >>
How to Install Docentric AX via Models >>
How to Unlock the Product >>
