How to Run a Docentric SSRS Report from Code
You can print a Docentric SSRS report from X++ using the standard approach of running an SSRS report from the code. The only difference is that you have to additionally specify that the target print destination is Docentric Screen/File/Email/Printer/Print Archive and set the corresponding settings.
To achieve some custom scenarios such as sending report to a web service, you can use Docentric Memory print destination to print report to a memory stream or container, and handle it from there as needed.
Learn how >>
Learn how >>
Generate and save Customer Invoice to Azure Blob storage
In the following example we are going to generate Customer Invoice using its built-in SSRS report design and save it to Azure Blob storage using the Docentric File print destination.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 |
public static void printSalesInvoice_useOriginalDesign() { SalesInvoiceController salesInvoiceController; SalesInvoiceContract salesInvoiceContract; Args args = new Args(); CustInvoiceJour custInvoiceJour; SalesInvoiceJournalPrint salesInvoiceJournalPrint; select firstonly custInvoiceJour where custInvoiceJour.SalesId != ''; // Add record to be printed. // In order to have the context table we need to set args.record(). args.record(custInvoiceJour); salesInvoiceController = SalesInvoiceController::construct(); salesInvoiceController.parmReportName( PrintMgmtDocType::construct(PrintMgmtDocumentType::SalesOrderInvoice).getDefaultReportFormat()); salesInvoiceContract = salesInvoiceController.parmReportContract().parmRdpContract(); salesInvoiceContract.parmCountryRegionISOCode(SysCountryRegionCode::countryInfo()); salesInvoiceController.parmArgs(args); salesInvoiceController.parmExecutionMode(SysOperationExecutionMode::Synchronous); // Set print destinations. SRSPrintDestinationSettings pds = salesInvoiceController.parmReportContract().parmPrintSettings(); pds.printMediumType(SRSPrintMediumType::File_DC); pds.parmFilePrintDestSettings_DC().parmOutputFilename('SalesInvoice_@FIELD_InvoiceId@.xlsx'); pds.parmFilePrintDestSettings_DC().parmOutputFileFormatSrs(SRSReportFileFormat::Excel); // Save to Azure Blob storage. pds.parmFilePrintDestSettings_DC().parmSendOutputFileToUser(false); pds.parmFilePrintDestSettings_DC().parmSaveToAzureBlobStorage(true); pds.parmFilePrintDestSettings_DC().parmAzureBsContainerName('docentric-report-output'); pds.parmFilePrintDestSettings_DC().parmAzureBsBlobPath('@COMPANYID@/Invoices'); pds.parmFilePrintDestSettings_DC().parmAzureBsOverrideFileIfExists(true); // Use the original SSRS design. pds.parmFilePrintDestSettings_DC().parmUseSsrsBuiltInDesign(true); pds.parmSrsPrintReportSettings_DC().setProperty_PrintSrsOriginalDesign(true); /* Use the default Docentric design */ //pds.parmSrsPrintReportSettings_DC().setProperty_PrintSrsOriginalDesign(false); //pds.parmFilePrintDestSettings_DC().parmUseSsrsBuiltInDesign(false); //pds.parmFilePrintDestSettings_DC().parmOutputFilename('SalesInvoice_@FIELD_InvoiceId@.pdf'); //pds.parmFilePrintDestSettings_DC().parmOutputFileFormat(DocOutputFileFormat::PDF); // Initalize SalesInvoiceJournalPrint class instance because there is no other way // NOT to use Print Management. salesInvoiceJournalPrint = SalesInvoiceJournalPrint::construct(); salesInvoiceJournalPrint.parmPrintFormletter(NoYes::Yes); salesInvoiceJournalPrint.parmUsePrintManagement(false); salesInvoiceJournalPrint.parmUseUserDefinedDestinations(true); salesInvoiceJournalPrint.parmPrinterSettingsFormLetter(salesInvoiceController.parmReportContract().parmPrintSettings().pack()); args.caller(salesInvoiceJournalPrint); args.parmEnumType(enumNum(PrintCopyOriginal)); args.parmEnum(PrintCopyOriginal::OriginalPrint); // Start the report execution. salesInvoiceController.parmShowDialog(false); salesInvoiceController.startOperation(); } |
How to Use the New Memory Print Destination >>
How to Change Print Destination Settings Dynamically >>
