Docentric SSRS Replicas
Each Docentric SSRS Replica consists of a Docentric design (aka template), which is a “smart copy” of the built-in SSRS report design, and the corresponding Docentric DSP class, which provides the basic set of custom placeholders available for use in print destinations. DSP classes also enables you to fully benefit from Print archive, emailing and distribution options enhanced by Docentric. And more importantly, Docentric DSP classes should serve as a starting point for your customization - by customizing them you can add additional data and placeholders without changing the built-in report artifacts such as SSRS temporary tables and DP classes.
Learn why and how to use them >>
Download Docentric SSRS Replicas
| Installation type | Instructions | Download link |
| Project with all replicas v3.5.0, supports all MS supported D365FO versions |
Contains the same model with all replicas, but more convenient for customization and maintenance.
CLICK TO DOWNLOAD |
| Model with all replicas v3.5.0, supports all MS supported D365FO versions |
How to import a model >> How to remove a model >> |
CLICK TO DOWNLOAD |
| Replicas templates v3.5.0, designed in MS Word |
A zip file containing Docentric templates for all Docentric SSRS Replicas. | CLICK TO DOWNLOAD |
Read Release Notes >>
View the complete list of available replicas >>
Download Docentric CBD Replicas >>
Docentric SSRS Replicas Upgrade Strategy
If you are considering to upgrade the Docentric AX SSRS Replicas model, please read this first >>
You can also contact us to discuss your options and scenarios.
What are Docentric SSRS Replicas >>
Which Docentric SSRS Replicas are Available >>
Why to Use Docentric SSRS Replicas >>
How to Use Docentric SSRS Replicas with Free Edition >>
How to Customize Docentric SSRS Replicas >>
