Docentric CBD Replicas
What are Docentric CBD Replicas
Docentric CBD Replicas are Docentric ER-based templates, which are "copies" of ER Formats of the corresponding Configurable business documents. They run on top of existing Docentric SSRS Replicas and their custom DSP classes.
When you run a report using a Docentric ER-based template, the configured report ER Model mapping is executed to generate the runtime DDSP (CBD DDSP). On the other hand, when a Docentric SSRS-based template is used, the configured report DSP class is responsible to generate the DDSP.
In both cases, the configured report DSP class, which belongs to the Docentric AX SSRS Replicas model, is responsible for populating Custom placeholders and report metadata needed for Print archive, Batch email sending status, Additional email attachments, Saving to Attachments, etc. as well as for customizations of print settings, if any.
Download Docentric CBD Replicas
| Installation type | Instructions | Download link |
| Project with all replicas v3.5.0, supports all MS supported D365FO versions |
Contains the same model with all replicas, but more convenient for customization and maintenance.
CLICK TO DOWNLOAD |
| Model with all replicas v3.5.0, supports all MS supported D365FO versions |
How to import a model >> How to remove a model >> |
CLICK TO DOWNLOAD |
| Replicas templates v3.5.0, designed in MS Word |
A zip file containing Docentric templates for all Docentric CBD Replicas. | CLICK TO DOWNLOAD |
Docentric CBD Replicas Upgrade Strategy
We recommend regular updates of the Docentric AX CBD Replicas model.
Which Docentric CBD Replicas are available
The Docentric CBD Replicas model contains Docentric templates for most common reports such as Sales invoice and Purchase order. Please find the complete list in Release Notes.
On the other hand, it contains extensions of the DSP classes for all reports supported by Microsoft as Configurable business documents and by Docentric as SSRS Replicas, with a single responsibility to populate Custom placeholders and report metadata contracts.
How to create new Docentric ER-based templates
To create a Docentric template for a report, which is not delivered by Docentric while it is supported by Microsoft as CBD, you can start from the existing Docentric template of the corresponding SSRS replica. After you configure ER Model mapping delivered by Microsoft for your report in Docentric report setup and generate the CBD DDSP, you can then use it in the existing SSRS-based template to change the data bindings according to the new data source schema. The changed template will become ER-based, and you can use it side-by-side with the SSRS-based template(s).
How to add additional data, placeholders and labels
- To add additional data -> use the configured report ER Data model and Model mapping.
- To add new placeholders -> use User-defined placeholders.
- To add new labels -> use User-defined labels.
- To change printing behavior or implement a custom scenario -> customize the report DSP class from Docentric AX SSRS Replicas via coding.
Docentric SSRS Replicas >>
Setup and Use of CBD Data Sources >>
