Import/Export License Plate Labels
For import/export of tables related to License plate labels we extended some of the standard data entities and implemented some new data entities. This table gives their overview.
| Data entity display name (Data entity technical name) |
Data entity purpose | Added/changed by Docentric |
| Document routing printers (WHSDocumentRoutingPrinterEntity) |
Import/export of Document routing printers | Extension WHSDocumentRoutingPrinterEntity.Extension_DCL added to support the new data fields added to Document routing printers (WHSDocumentRoutingLine) table. |
| Docentric Document routing printers (DocWHSDocumentRoutingPrinterEntity) |
Import/export of Docentric Document Routing Printers | New entity added to support import/export of Docentric Document Routing Printers (DocWHSDocumentRoutingLine) table added by Docentric. |
| Document routing label layout printers (WHSDocumentRoutingLabelLayoutLineEntity) |
Import/export of Document routing printers with new Label layouts | Extension WHSDocumentRoutingLabelLabelLayoutLineEntity.Extension_DCL added to support the new data fields added to Document routing label layout printers (WHSDocumentRoutingLabelLayoutLine) table. From v3.4.8 |
| Label layout data sources V2 (WHSLabelLayoutDataSourceV2Entity) |
Import/export of Label layout data sources | Extension WHSLabelLayoutDataSourceV2Entity.Extension_DCL added to support the new data fields added to Label layout data source (WHSLabelLayoutDataSource) table. From v3.4.9 |
Docentric Data Entities (Data Management) >>
Import/Export Docentric report setup (Deployment Tools) >>
