Improved License Plate Labels
Docentric improves License plate labels in terms of design, setup and printing, starting from version 3.4.4.
With Docentric, you can:
- Use Docentric templates instead of ZPL layouts (Document routing layouts and new Label layouts), which brings:
- Easier and user-friendly label design with Docentric Designer in MS Word with instant preview instead of using command oriented ZPL language,
- Effortless use of barcodes and images such as company logo and item image on label designs.
- Add additional data to be printed on license plate labels:
- Via DSP classes or by extending the report query (coding and deployment required),
- Via Electronic reporting (no coding and deployment required).
- From v3.4.9: Via UI query behind Label layout data sources (no coding and deployment required).
Label layout data sources are shipped with ZPL-based Label layouts in D365FO v10.0.36.
- Simplify Document routing setup by configuring additional conditions per Document routing line. By default, conditions can be configured only per Document routing header.
- Use Dynamic printer selection for routing and printing labels based on both ZPL layouts and Docentric templates.
Dynamic printer selection is shipped in D365FO v10.0.36.- Configure Fallback printer for Dynamic printer selection if no printer is resolved. Fallback printer is shipped in D365FO v10.0.41 for ZPL layouts and is supported from v3.4.9 for Docentric templates.
- Print preview and Test Document routing setup against a license plate label.
- Make license plate labels multilingual and label language configurable.
- Reprint license plate labels from D365FO (from the License plate labels or Document routing setup forms), not just from the Warehouse mobile app.
- Monitor printing status via label metadata such as Warehouse, Work, License plate and User in Document routing status.
Learn how DRA works >>
Learn how to reduce printing delay for the built-in DRA >>
Enable License plate labels
Turn on the Enable License plate labels feature in Docentric AX parameters > Product > Product configuration to:
- enable using the Docentric templates instead of Document routing layouts and Document routing setup, and
- enable the above listed printing improvements.
Once you turn on the Enable License plate labels option, the following menu items and form controls become visible:
- The Document routing form:
- The Query criteria field in the Overview tab, which shows the header condition query criteria if configured.
- The Edit query button and the Mobile device user IDs, Run query, Query criteria configured, Query criteria and Dynamic printer selection columns in the grid Document routing printers. These controls enable setup of conditional Document routing lines.
- The Docentric Document routing printers tab which enable use of Docentric templates instead of ZPL layouts and setup of conditional Document routing lines.
- The Document routing and License plate labels forms:
- The Test setup menu item which opens a form where you can test Document routing setup against a selected license plate label.
- The Print label menu items which enable print preview and print of a selected license plate label, with or without Document routing setup, using both Docentric templates and ZPL layouts.
- Docentric report setup form:
- OOTB loaded report DocWHSLicensePlateLabel.Report bound to a special DSP class DocWHSLicensePlateLabelDSP with two Docentric templates, one SSRS-based and second ER-based. The latter is loaded only if the CBD data sources feature is turned on. These templates contain a sample design of License plate label you can use as a starting customization point.
- On the Report template and Report template file forms a new fast tab Warehouse labels is added but it is visible only if the report represents a Warehouse label. This information is inferred from the report DSP class.
In the Warehouse labels fast tab you can configure Printer stock type for a Docentric template document, which determines the size and type of paper that the label with this template requires when printed, and which can be used for Dynamic printer selection.
Additionally, from v3.4.9 you can specify which Label layout data source configuration will be used as data source for the template. The selected Label layout data source configuration will override the data source defined in the DSP class of the report.
- The Label layout data source form:
- The Docentric data source menu with menu items for creating and modifying data source query.
- Two new fields in the form grid to identify which Label layout data source records are ready to use to with Docentric.
Free and Full Edition features
All features of improved License plate labels which are related to ZPL layouts and not related to Docentric templates are delivered as part of Free Edition. Both ZPL layout types (Document routing layouts and new Label layouts) are improved with Free Edition in terms of setup and printing.
Free Edition features include:
- Simplified Document routing setup due to possibility to conditionally execute Document routing lines, by configuring Mobile device user IDs and condition queries. Learn more >>
- Test Document routing setup without printing license plate labels to network printers. Learn more >>
- Reprint license plate labels from D365FO, with or without using Document routing setup. Learn more >>
- Use Dynamic printer selection for label routing and printing. Learn more >>
Full Edition features include:
- Use Docentric templates instead of / in addition to ZPL layouts.
- User-friendly license plate label design.
- Multilingual license plate labels and configurable label language.
- Print preview.
- Non-developers can add additional data to the data source of the License plate label report by using the report ER Model mapping. Learn more >>
- From v3.4.9: Non-developers can use Label layout data sources for Docentric templates to add additional data via the UI query behind a Label layout data source. Learn more >>
- Monitor print jobs in Document routing status via label metadata such as Warehouse, Work, License plate and User.
Learn more >>
Security
We didn’t add any custom security for the License plate labels functionality but we extended the existing duties related to view and maintain privileges for Document routing and License plate labels in the following way:
- Any user who can open the License plate labels form (read or write) can also test the setup (the Test setup menu item) and print labels (the Print label menu items) using Docentric functionality.
- Any user who can open Document routing (read or write) can also configure any of the above Docentric improvements, including testing the setup and printing labels.
Download Docentric templates and ER configurations
Described functionalities improving License plate labels are developed as artifacts placed in a separate model Docentric AX Warehouse Labels. You can download this model alongside other Docentric core product models.
Learn more on Docentric core product models >>
Among other artifacts in the Docentric AX Warehouse Labels model, there is also a Docentric sample template (DocWHSLicensePlateLabel.Report.docx) we created as a starting point for your customization.
In the case that you are using CBD (Electronic reporting) data sources, in the Docentric AX Warehouse Labels model there are also Electronic reporting configurations, ER Data model (DocWHSLicensePlateLabelModel.v3.4.8_or_above) and Model mapping (DocWHSLicensePlateLabelModelMapping.v3.4.8_or_above), as well as the template based on them (CBDDocWHSLicensePlateLabel.Report.docx).
If you're using Docentric AX version 3.4.7 or below, then use the appropriate model (DocWHSLicensePlateLabelModel.v3.4.7_or_below) and model mapping (DocWHSLicensePlateLabelModelMapping.v3.4.7_or_below).
Since Docentric templates are provided as AOT resources, they will act as System templates and be loaded into Docentric report setup automatically, when you for the first time open Document routing setup. You can download them from there and adjust the design according to your needs. Nevertheless, you can download them also from this page.
Regarding the ER configurations, in one of the future versions we will create a Docentric repository on RCS (Regulatory Configuration Service) with all ER configurations provided by Docentric, including these two for License plate labels. Until then, you can download it from the model's AOT Resources from Visual Studio on a development environment or from this page.
| Download Docentric templates and ER configurations |
See Also
How to Setup and Print License Plate Labels >>
Label Layouts and Dynamic Printer Selection >>
Using Docentric Templates with License Plate Labels >>
How to Add Additional Data to License Plate Labels >>
Import/Export License Plate Labels >>
