When previewing Print management reports such as Project invoice and Purchase order through Original preview and Copy preview on journals, the result are documents generated using the DEFAULT report design. This is simply because Original preview and Copy preview work without considering Print management setup.
On the other hand, when printing the same reports via Use print management on the same journal forms, the resulting documents are generated using the report design configured in Print management setup.
In short, Print management preview enables you to preview reports from the journal forms using the report designs selected in Print management setup, and it works for both SSRS and Docentric designs.
Check how to use Print management preview with SSRS report designs >>
Print management preview used with Docentric designs
The following video shows the Print Management preview feature in action when using Docentric templates. Enjoy! 🙂
There is more!
See the overview of all improvements >>
Print Management Preview
Tags: D365FO, Full Edition, Invoice, Print management, Video
