How to Use More Than One Template per Report
Default report templates
Each Docentric report can have more than one template assigned, but one group of templates with the same Template ID always acts as so called default templates. When a report runs, a single default template is automatically selected considering the run-time language (usually current user language or, e.g. Customer language) and company (usually current company). Templates can be also company and language neutral.
Thus, if we want to have for the same SSRS Report Design (e.g. SalesInvoice.Report) different Docentric's templates for different companies and languages at our disposal, no coding is needed. Which (default) template will be automatically selected depends only on the report template setup.
In the above example:
- If the run-time company is USMF and the run-time language EN-US ->
the template with Template ID = 'SalesInvoice.Report', Company ID = 'usmf' and Language ID = 'en-us' is used. - If the run-time company is USMF and the run-time language DE ->
the template with Template ID = 'SalesInvoice.Report', Company ID = 'usmf' and Language ID = '' (language neutral) is used. - If the run-time company is JPMF and the run-time language EN-US ->
the template with Template ID = 'SalesInvoice.Report', Company ID = '' (company neutral) and Language ID = 'en-us' is used. - If the run-time company is JPMF and the run-time language DE ->
the template with Template ID = 'SalesInvoice.Report', Company ID = '' (company neutral) and Language ID = '' (language neutral) is used.
And if we want to change the default behaviour of template selection and to use a non-default template (e.g. SalesInvoice.Report_AlternativeTemplate) instead of the default one, the only way to do this is to switch templates dynamically, i.e. during report execution. Hence we have to create a custom DSP (Data Source Provider) class, and implement the overrideReportRunSettings() method. In this method we can also change the selected print destination and its settings, replace custom placeholders, etc. Learn more >>
Print Management reports
Let’s say we have different invoices for different customers. With Print Management framework we can set up different Designs of an SSRS report to be used for printing a report when the required conditions are met.
However, if the built-in Print Management framework does not allow us to set all conditions we need, we can select the required template dynamically, i.e. in the code:
- We have to create a custom DSP (Data Source Provider) class using the wizard, if we haven’t already do that (e.g. in order to extend the existing data source with some additional data)
- Implement the overrideReportRunSettings() method of this class to dynamically select a report template. In this method we can also change the selected print destination and its settings, replace custom placeholders etc.
Ordinary SSRS reports
On the built-in report dialog form we can select report parameter values as well as a print destination but we cannot select a template. When a report executes one of the default templates is used. We can change this only if we dynamically switch the template in the code.
Thus, we have to create a custom DSP class using the wizard and implement the overrideReportRunSettings() method. Learn how >>
We can also enable selection of a template on the report dialog form by adding Template ID, Company ID and Language ID as Data Member Attributes to a SSRS Report Data Contract. This makes them visible as report parameters on the report dialog form so end users get an option to select a particular template among all other report parameters.
Learn more on how to enable selection of a template on the report dialog form >>
Learn more about default report templates >>
Make your own setup extension for a specific report
In both cases (a Print Management report and an ordinary SSRS report) we can make our own setup extension with UI support for the sake of end users.
This means that for a specific report, e.g. Invoice we can introduce an additional setup table that is related to the tables DocReportTable and DocTemplateTable, and also to other tables, e.g. CustTable that play a role in the conditions to select a particular template.
Then in the overrideReportRunSettings() method of the custom DSP class of the Invoice report apply the business logic based on your setup and select the proper report template.
How to Dynamically Switch Selected Template >>
How to Use a Built-in SSRS Report as Docentric Report >>
How to Use a Print Management SSRS report as Docentric Report >>
