Skip to content
Advanced Reporting for Dynamics 365 for Finance and Operations
+386 47 774 180 (EU), +1 650 835 7260 (US) | Call back | info@docentric.com
    Docentric respects you privacy. For information about how we handle your personal data, please read our privacy policy.
    • Home
    • Product
      • Features
        • Key Features
        • Design Capabilities
        • Feature List
      • Free Edition
        • Free Edition
        • Free vs. Full Edition
      • Architecture
        • For D365FO
        • For AX 2012
      • Videos, Brochures & Benefits
    • Download
      • Download free edition
      • Download Full Version
      • 👋 Book a demo!
    • Support
      • Get Support
      • Forum
      • How-To Manuals
        • For D365FO
        • For AX 2012
      • Video Tutorials
      • Blog
    • Purchase
      • Pricing
      • Upgrade to Full Version
      • Buy
      • LEGAL
        • EULA
        • Free Edition License
        • Maintenance and Support
    • Company
      • About Us
      • Careers
      • What our clients say
      • Partner Corner
        • Partner Corner
        • Partner of the Year
      • Contact Us
      • Privacy
        • Privacy Policy
        • Diagnostics Data Collection
        • Cookies
        • Privacy control
    MS Dynamics AX 2012
    CONTENTS
    X
    • Installation
      • Trial Product Installation
        • How to Install Docentric AX Framework via Model
        • How to Install Docentric AX Framework via XPO Files
        • How to Install Docentric AX Template Designer
        • How to Remove Docentric AX Framework
      • Licensed Product Installation
        • How to Install Docentric Server
        • How to Unlock the Product with a Valid License
      • Product Upgrade
        • How to Upgrade Docentric AX Framework
        • How to Upgrade Docentric AX Template Designer
        • How to Upgrade Docentric Server
    • Docentric AX Setup
      • Docentric AX Framework Setup
        • How to Set Up Docentric Server Parameters
        • How to Set Up Reporting Parameters
        • How to Set Up Document Types for Archiving Reports
        • How to Set Up Reports
        • How to Set Up Word Templates
      • Docentric Server Configuration
    • Docentric Word Templates
      • How to Create a Docentric Template Library
      • How to Create a Word Document with DSP Class
      • How to Create a Word Document with DSP Query
      • How to Update an Existing Word Document
      • How to Generate a Word Document from Code
    • Docentric SSRS Reports
      • How to Use a Built-in SSRS Report as Docentric Report
      • How to Use a Print Management SSRS report as Docentric Report
      • How to Add Additional Data to a Docentric SSRS Report
      • How to Develop a New SSRS Report
      • How to Use More Than One Template per Report
      • How to Use the Original Design of a Docentric SSRS Report
      • How to Use Placeholders in Print Destination Settings
      • How to Dynamically Change Print Destination Settings
      • How to Run a Docentric SSRS Report from Code
      • How to Send a Docentric SSRS Report to Multiple Print Destinations
      • SSRS Report Docentric Replicas
    • Docentric Basic Reports
      • How to Create a Simple Docentric Basic Report
      • How to Create a Complex Report Dialog Form
      • How to Run a Report in the Context of an Underlying Entity
      • How to Use More Than One Template for a Report
      • How to Run a Docentric Basic Report from Code
      • How to Run a Docentric Basic Report in Batch
      • How to Suppress a Success Message after Report Execution
      • How to Send a Docentric Basic Report to Multiple Print Destinations
      • Docentric Basic Report Execution Hooks Overview
    • Data Source Provider Classes
      • How to Write a Data Source Provider Class
      • Docentric Data Source Packages (DDSP) Overview
      • How to Extend Data Sections of DDSP
    • Report Print Destinations
      • Report Print Destinations Overview
      • How to Dynamically Switch Selected Template
    • Template Design
      • Docentric AX Template Designer
        • Docentric AX Template Designer Overview
        • XPath Expressions
          • XPath Selecting and Filtering Nodes
          • XPath Functions
          • XPath Operators
        • Formatting Report Data
        • Report Preview
        • Using If Tagging Element
        • Using Visual Format Override
        • Using Var and Context Tagging Elements
        • How to Calculate Running Total
        • Inline and Floating Objects in MS Word
        • Last Page Footer
      • Template Examples Step by Step
        • Example 1: HCM Birthday Report
        • Example 2: HCM Birthday Report with Grouping
        • Example 3: Purchase Order Print Management Report
        • Example 4: Number of Workers Report
        • Example 5: Purchase Order Basic Report
        • Example 6: Sales Invoice Report
    • Miscellaneous
      • Report Import/Export Functionality
      • How to Make Multilingual Reports and Documents
      • Barcodes and Labels
      • How to Quickly Build Custom XML
      • How to Write a Sufficient Support Mail
    • Examples
      • Word Template Examples
      • SSRS Report Examples
      • Basic Report Examples
    No results for .
    How-To Manuals AX 2012
    How-to manuals for Docentric AX for MS Dynamics AX 2012 R2/R3 are grouped by the following sections:
    • Installation
    • Template Design
    • Miscellaneous
    • Examples
    Get started with Docentric AX
    The recommended sequence of how-to manuals to get you started after installation:
    1. Docentric AX architecture
    2. How to setup Docentric AX Framework
    3. How to use SSRS Reports with Docentric AX
    4. How to use Document Template Libaries (Word documents) with Docentric AX
    5. How to use Docentric AX designer
    6. How to prepare data for a report or a document
    7. How to use Docentric Basic Reports
    Download and use already prepared real world examples for your rapid start with Docentric AX.
    Product
    • Key Features
    • Design capabilities
    • Feature list
    • Free Edition
    • Architecture for D365FO
    • Architecture for AX 2012
    Support
    • Get Support
    • Forum
    • Feature Request
    • How-To Manuals D365FO
    • How-To Manuals AX 2012
    • Video Tutorials
    • Video Library
    • Blog
    Purchase
    • Pricing
    • Buy
    • EULA
    Company
    • About Us
    • Careers
    • What Our Clients Say
    • Partner Corner
    • Contact Us
    • Privacy Policy
    • Privacy Control
       Download Docentric AX
    Microsoft Gold Partner
    Follow us
    Linkedin Twitter Youtube Instagram
    Newsletter subscribe
      Copyright © 2026 Docentric d.o.o. All Rights Reserved.
      Back to top
