Design your reports in MS Word while using Electronic Reporting configurations as data sources, electronically sign and email reports or save them to various storage types - those are just some of the topics that will be covered in this session packed with live demos. Our experts Sanja Kolundžija & Albin Lotrič will show you some of the most sought-after D365FO reporting improvements available only with Docentric. As a cherry on top 🍒, you will see our latest features in action.
Session's Agenda
✅ Design your reports in MS Word while using Electronic Reporting configurations as data sources.
✅ Electronically sign and email reports.
✅ Save reports to various storage types.
✅ Design License plate labels in Word rather than ZPL language.
✅ Simplify Document routing setup.
✅ Test Document routing setup without printing.
✅ Preview and reprint License plate labels.
And more❗
View PowerPoint Presentation
See Gallery
#MySummitNA 2022: Top 7 D365FO Reporting Challenges You Can Solve Only With Docentric
Hi Albin
Great Video!!
These really helped me :).
How do i hide an existing field or columns in a sales invoice report in ER?
Thanks
Shereen
Hi Shereen,
I assume that your question relates to Docentric AX Designer, which can also be used for designing templates, based on ER data models and data mappings. When you want to hide a field, you can wrap it in a conditional content (IF tagging element) and write the expression, which returns true or false; if true, the content is shown, otherwise it is hidden. Hiding a column can be achieved by applying a Visual Format properties on one of the Field tagging elements in the column which you want to hide. You need to set the target to current column and enter the expression which returns true (visible) or false (invisible). If you would like more detailed information, please send an email to support@docentric.com.
