When printing the reports from D365FO in the cloud, many business scenarios require routing the created documents to the local file system. Unfortunately, standard D365FO doesn’t provide this possibility, resulting in difficult access to the printed documents, as well as problems with legacy integrations via shared folders on file system. Join us at this session to learn how Docentric solves the described challenge in a convenient and configurable way. The trick is in saving the generated documents to Azure file shares which can be mounted as network drives.
Watch Session
View PowerPoint Presentation
DynamicsCon presentation: Print Reports from D365FO to Local Network via Azure Files >>
See Gallery
DynamicsCon 2022: Print Reports From D365FO to Local Network via Azure Files
Tags: Azure Files, D365FO, Full Edition, Print destinations, Video
