A new version of Docentric AX has been released. The new release contains the following new functionalities:
- Added support for (dynamic) query based SSRS reports.
- Improved support for query based Word documents.
- Added additional data fields to the GeneralData data section: Bank Account IBAN, Swift, and Name.
- Improved use of custom DSP classes for Docentric SSRS reports:
- A new method onSelectedRdpTableRecord() is added.
- Overriden methods for modifying the GeneralData data section are enriched.
- Printing is moved to Docentric Server in order to truly support reliable server side printing. However, printing can be configured to still run on AX client/AOS, but this is not recommended any more.
- Improved email sending:
- Email sending settings are introduced: Choose if you want to send emails always via AOS, by using Outlook app or Smtp client
- For Email To, Cc, and Bcc settings end user can select and use SRS print destination tokens
- Names of temporary files can be created using GUID as well.
Tags: Version releases
