Intro
This topic will serve as a hub for newly released versions of Docentric and will allow you to subscribe and get an email notification for every new Docentric version.
Every new Docentric version will be written down as a reply to this topic, with either a link to the blog post about the new release (for new version releases) or with a short summary (in the case of hotfixes).
How to Subscribe to Get Notified
To be able to subscribe, you will first have to create an account on our forum.
We invite you to join our community, which will also enable you to share ideas and get help from both Docentric AX experts and fellow D365FO community members.
To subscribe to this topic, you need to scroll down, below the last reply at the bottom of this page, click on the bell icon and choose Watching.
Please note that you need to enable email notifications in your preferences:
Other Ways to Stay Informed About New Docentric Releases
There are also other ways to follow new Docentric version releases:
How to Send Feedback
We welcome and value all feedback, so if you have any feature requests or bug reports, feel free to share them with us by creating new topics on our forum or by contacting our support (support@docentric.com).
Docentric AX v3.5.0 released - 2025-10-02
Highlights: Print from journals; SFTP delivery; Print archive cleanup.
Full release notes in the Blog: Docentric AX 3.5.0 Released
New Features
- Print reports from common journals (Free Edition): Users can now print reports directly from common journal forms (interactively, in bulk, or in batch) with or without using Print management.
- Send reports to SFTP (Full Edition): A new SFTP print destination allows reports to be sent directly to SFTP servers with support for various authentication methods and dynamic path/filename configuration.
- Print archive cleanup job (Free Edition): A new periodic job is available to clean up the Print archive based on specific criteria like report ID, user, or date of the record.
Quality Improvements Areas
- Internal Azure Blob storage: Improved error handling and file naming validation when saving files to internal storage.
- Docentric Designer and Document Generator: Resolved barcode generation issues for specific types and fixed XML serialization errors for DDSP files.
- Emailing: Fixed a report download issue when ‘Email without report’ and ‘Preview’ are both enabled and resolved permission restrictions for the ‘Restart send’ button in the Batch email status form.
Docentric AX Hotfix v3.5.0.1 - 2025-10-07
Quality improvement areas
General: Added delegates to support the import of custom extension fields into report templates.
Advanced Filter or Sort: Resolved “RegisterOverrideMethod” and “Master FormDataSource” errors.
System and Utilities: Fixed a critical issue where the AOS would crash and restart during an Azure Blob Storage reconnection attempt following a token expiration.
Docentric AX v3.5.1 released - 2026-02-18
Highlights: Report attachments; e-Invoicing; Advanced email tokens.
Full release notes in the Blog: Docentric AX 3.5.1 Released
New Features
- Report Attachments (Full Edition): Added support for other print destinations, enabling rules for loading or generating documents with new options to merge, embed, or print them as separate files.
- E-Invoicing: Enabled the generation of ER-based e-Invoices (UBL, PEPPOL…) in parallel with the main report, including full support for ZUGFeRD/Factur-X by embedding XML data, applying XMP metadata, and converting the final output to PDF/A-3 format.
- Advanced Email Tokens: New way of email address resolution from multiple sources (Invoice, Order, Project, etc.), including related Contact persons and Logistics addresses.
- General: Resolved a report printing failure to Azure Blob storage caused by invalid contract casting when Print management records are missing, fixed XML validation errors in build pipelines caused by special characters, and corrected a cross-company execution bug for alert rules
- SFTP File Destination: Fixed path resolution logic to ensure relative SFTP paths are resolved against the working directory instead of the root.
- Template Data Security: Fixed an issue where Docentric security roles assigned indirectly through role hierarchy were not recognized.
