Hi all, we are on 10.0.41 PU65(7.0.7367.155) with the latest PQU. Docentric AX is 3.4.8.5, Docentric AX Extension is 3.4.8.5. In Tier-2 environment, when I try to upload a report to SharePoint, I am getting the following error.
Unable to obtain SharePoint access token. Details: An empty access token was returned. Authorization to SharePoint not possible.
It was working fine last week.
In the production and CHE, I don’t have this error.
Does anyone have this issue?
Did the upgrade work or was it fixed some other way. We have the exact same scenario. Work in Stage (Tier-2) a few weeks ago and now it doesn’t. Works in Prod fine.
Hi Mel, yes, the upgrade worked. It is same for me. It was working until last week and stopped working in all Tier-2, while Prod is fine. also DEV (CHE) is also fine. Not sure what happened, but it is good upgrading fixed that. Thank you!
please do, because it explains all the details about SharePoint user authentication changes, and you will find the answer to why it is different for different Stages.
Hi Albin, we have a problem with the batch connection. I run the powershell script in the article, but the connection in batch still fails. I appreciate if you could give me suggestions. Thank you!
