Nicky
                (Nicky Joubert)
              1
              Hi Support,
On the attached, I need to replace the @ProjIdInter field under the Description with the @Name field, if the @ProjIdInter field is empty.
I tried modifying the expression in a 2022 post on the forum but it’s not working.
Thank you.
2004-FreeTextInvoice.Report (43).ddsp (193.8 KB)
2004FTI.docx (67.8 KB)
                BlazJ
                (Blaž Jensterle)
              2
              Hi there @Nicky,
The easiest way to achieve to display a different field under a certain condition is to use an iif() function.
The expression in your case should look like this.
iif(@ProjIdInter = '', @Name, @ProjIdInter)
I have modified the template for you as well. You can check the solution there.
2004FTI (Edited by Docentric).docx (65.9 KB)
