Receiving the following compile error after deploy 10.0.26 vm
The Class ‘ERSolutionLabelRepository’ is internal and is not accessible from the current module ‘Docentric AX’
Hi Pamela, welcome to Docentric forum and thank you for your question.
It appears that you are not using the latest version of Docentric that is compatible with the D365 version you are using. What version of Docentric do you currently have? You can check this by going to Help > About > Version:
Please let me know.
You can read more about Docentric’s compatibility with versions of D365FO here:
The customer is using 3.4.2.2
D365 version is 10.0.26
Hi Pamela,
due to some changes on Microsoft’s side, you should use the latest version of Docentric that is compatible with the Dynamics 365 version you are using.
Please contact our technical support where you can get all the necessary information to update Docentric to the latest available version.
