When sending e-mails from D365FO using Docentric’s email templates, you can configure both the sender address and sender name:
However, it’s important to note how this behaves depending on the email provider:
SMTP: The configured sender name is correctly shown to the recipient.
Microsoft Graph: The sender name is overridden by Graph and not shown as configured. This is a limitation of Graph, designed to prevent spoofing and phishing.
Exchange: Supported up until D365FO version 10.0.38.
The above limitations also apply to standard D365FO Organization email templates and System email templates.
Recommendation: If your organization uses Microsoft Graph as the email provider, please be aware that the sender name set in templates will not be reflected in the recipient’s inbox. We suggest using SMTP if displaying a custom sender name is essential.
