Reports not pulling correct Delivery terms translation in docentric
Is there any solution so docentric report can pull the right delivery terms translation? not the label but the field translation
@DalilaI @BlazJ @AmirO
Hi Momo,
Welcome to our community.
If I understand you correctly, you would like Docentric to have the ability to automatically translate field values, which is not possible.
However, there is an option to define Terms and Conditions attachments in multiple languages and, in Print Management, specify the rules for selecting the appropriate attachment if you are using our Additional Attachments functionality.
I’m not entirely sure about your exact use case, so I would kindly ask you to provide a bit more detail regarding your requirements.
Hi Momo,
My colleague’s answer did not directly address your question, so I am providing additional information.
D365FO can read some translations by default, but not all. I quickly created a sales order in my Contoso test database in legal entity DEMF, which uses German. I created a translation for delivery mode 10, which is “Truck” in English and “Lastkraftwagen” in German. I also translated one of the released products with ItemId = D0001. When I posted the invoice based on this sales order, I saw that the translated item name appeared on the invoice, but the delivery mode remained in English. Obviously, SSRS, where Docentric intercepts the data, does not read the translation for this field. Below is the section from the DDSP file that demonstrates this:
If you are a Docentric partner or a customer with technical support, we can provide you with a code sample showing how to extend the DSP class, where Docentric prepares the data for the report, and how to read the translated value for the mode of delivery. In this case, contact us directly to support(at)docentric.com.
Kind regards,
Albin
