Multiples Notes and DDSP: Ex: SalesConfirmation.Report
Situation:
We are adding multiple notes to the SO-xxxxx Header area, but the DDSP are being created with ONLY one Notes section ignoring the second string of notes.
Expectation:
Have an answer about if is the NOTE section able to concatenate multiple Notes or just one?
Ex:
Notes="Forced Convection Reflow/Cure Syst
Hi @HellerIT
Can you send the DDSP in question? If it contains sensitive data, you can send it to support@docentric.com and we will continue there. Can you also provide the entire content you expect to show. Also it would be great to show that content as screenshot in the D365FO form where you configured it. Thank you.
Semir, we found that the Restriction needs to be EXTERNAL on both Notes. After modification the XML string is now consolidating information from both.
Hi @HellerIT
Great to hear it is working and thank you for sharing!
