Is it possible to retrieve the context language used to translate labels?
We are actually looking for integrating our GSC inside a multilingual report. We can not put all the GSC into a user-defined label so the idea was to use an “if” element with a condition on the context language because we do not find this data in the DSP. Is it the right way of thinking to acchieve our goal ?
Hello @Sephane,
I’m not sure I fully understand the question. What does GSC stand for?
However, I think you will find this information useful.
Namely, in the General Data section of your report’s DDSP file, you can find the Misc/@LanguageId field, which holds the value of the current language ID.
I believe you can use this field in combination with an if tagging element for your scenario.
Hope this helps!
