We have a legal requirement for Canadian customers in certain regions to supply all documentation with both the Canadian French and English translations on each label used within the template layout. For a example a field with the system label for county would appear to the user as ‘County/Comté’.
When generating the DSP files we have the option to include label translations for multiple languages. Is there a way to replicate this when generating a docentric document?
In standard SSRS design and Docentric template, the label is translated using the runtime language. This means that only one translation is used to populate label values when the report is executed.
Including translations for multiple languages in the data source is used only by Docentric during the design phase to enable users to view the preview of the template in different languages.
You could create User-defined labels that would have literal bilingual translations and then include these labels on the templates instead of the existing ones. You can base them on System labels so other translations are taken automatically and only translations for specific languages are changed. You can read more here: User-Defined Labels - Docentric AX
