How can I add 2 different fields within a column
How can I add the Net invoice (@lineamount) with the autocharge (@TaxFreeBalance)
Hi, Damilare, and welcome to our Forum!
I assume that you would like to know how you can summarize values in @LineAmountInclTax in invoice lines and then add @TaxFreeBalance to the result.
To achieve this, edit the Field tagging element where you now have @TaxFreeBalance and add the following expression:
sum(SomeLinesData/@LineAmountInclTax) + SomeHeaderData/@TaxFreeBalance
Replace SomeLinesData and SomeHeaderData with correct paths as needed.
If my assumption is not correct or you cannot get expected result from the explanation above, you can also send your template to support@docentric.com and our support team will take a look and provide the solution.
Kind regards,
Albin
Thank you Albin, That fixed it
Happy to hear that, Damilare!
