When you have charges added to your Sales Invoice, they will be reflected in your report data source, including setting the ShowMarkupTrans field to true.
However, this works only for Finnish legal entities.
If you’d like to show the charges in your report data source, you can customize the DSP class to populate the data source with the MarkupTrans node.
private void addMarkupTrans(DocXmlRecord _dataRecord, Common _tableRecord)
void addMarkupTransDataRecord(MarkupTrans _markupTrans)
DocXmlRecord markupTransDataRecord = _dataRecord.addChildRecord(_markupTrans);
markupTransDataRecord.addField(fieldStr(MarkupTrans, LineNum));
markupTransDataRecord.addField(fieldStr(MarkupTrans, MarkupCode));
markupTransDataRecord.addField(fieldStr(MarkupTrans, Txt));
markupTransDataRecord.addField(fieldStr(MarkupTrans, Value));
markupTransDataRecord.addField(fieldStr(MarkupTrans, CurrencyCode));
markupTransDataRecord.addField(fieldStr(MarkupTrans, TaxGroup));
markupTransDataRecord.addField(fieldStr(MarkupTrans, TaxItemGroup));
MarkupTrans markupTrans;
boolean markupTransDataRecordAdded = false;
while select markupTrans
where markupTrans.TransRecId == _tableRecord.RecId &&
markupTrans.TransTableId == _tableRecord.TableId &&
!markupTrans.IsDeleted
addMarkupTransDataRecord(markupTrans);
markupTransDataRecordAdded = true;
// Add an empty record but only at design time, if no markup record exists.
if (!this.isRuntime() && !markupTransDataRecordAdded)
markupTrans.clear();
