Is it possible to change values on labels/fields depending on dynamic input?
For example, if we would like to print a PO which could be of type project or material,
can we adjust the labels on the order lines to switch from
Description (if type project) or 2. Item name (if type material).
And also, if PO is of type Project we want to show fetch value from @name in the field, but if it is of type Material we want to show @ItemId. Is this possible?
Iit is possible to achieve your objective by utilizing the field tagging element and Xpath function "iff()".
The following syntax can be used as an example:
iff(@type=‘Project’, @Description, @Material)
This will enable you to display the Description field when the type is “Project”, and the Material field when it is not. Please refer to the attached image for reference.
