User defined place holder expression error
Getting the following expression design error when trying to create a user defined place holder. Not sure what it means.
INVALID_EXPRESSION: Expression has returned 2 XML elements. Expected exactly one.
Hi @dpeters,
As the error states, your expression returns more than one XML element. You can use square bracket notation [ ] to filter and show only one element.
For example, our SalesInvoice.Report has multiple SalesInvoiceLines records so if you use:
SalesInvoiceLines/@DiscountAmount
you get the error: INVALID_EXPRESSION: Expression has returned 5 XML elements. Expected exactly one.
Then you use filtering to show only first SalesInvoiceLines record:
SalesInvoiceLines[1]/@DiscountAmount
Thank you, that worked.
