I’ve this error:
Where can I increase the timeout value?
Hi gtava,
The default 180 seconds timeout threshold for the document generation was exceeded. I can also see that the print destination was changed from Docentric Screen to Print archive because of batch processing.
Timeout can happen because the amount of data is so large that the processing can’t finish within 180 seconds. Another reason can be that the template is using some design approach which consumes a lot of resources and the timeout can happen even with moderately large amount of data.
If you’d like, you can send the template to us for a review to support@docentric.com.
