How to add a new column in a table : Value coming only in the top row not all row
I am facing problem to create a new column in an exiting table : after create the new column, when including field its populating only in the first row not all row even though I selected the field PurchPrice from line level. See below
Please suggest me, how can I get value for each row?
Hi there @mhaque and welcome to the Docentric Forum!
Based on the screenshots you have attached, it seems that you are missing a List tagging element, which would return the @PurchPrice field for each row.
Please go ahead and check out this tutorial on our YouTube channel: Template designer: List tagging element
This will give you an insight on how to use the List tagging element.
If you are still having problems after that, please attach your report template here so that we can take a look.
