Dear Support Team, I have a following problem.
Yesterday I tried to import the xlsx file that I exported (via DMF) from UAT Environment of the customer.
We had this query : - Setting -Original Email and No Email:
The customer overwrites the data on the UAT with production data, so that the print destinations should be set afterwards.
After the import I cannot open the print destinations in module project, the error is – the query has a bad container.
We tried to play a bit with the file and found out that the problem lays in this two records (or in column packed query) but we don’t know what is the problem. To avoid the error with the query bad container, we deleted via SQL the two following records.
DESCRIPTION NUMBEROFCOPIES PARENTID PRINTJOBSETTINGS PRIORITYID QUERYPACKED REPORTFORMAT SUPPRESS DATAAREAID PARTITION RECID RECVERSION
Original - Email 1 5637158102 NULL 2.0000000000000000 NULL 0 0 110 5637144576 5637158860 1
Original - keine Email -> Standarddrucker des Users 1 5637158102 NULL 3.0000000000000000 NULL 0 0 110 5637144576 5637158861
Finally I made the setup manually. But after 2 weeks I’m facing the same problem again. I added the xlsx file in the attachement. Could you please tell me what is wrong in the file? Thanks in advance.
