Docentirc editor: insert rows in table within an if tagging element
Hello,
If I put an if taggging element on a table row, can I insert an additional row within the if tagging element? Is there a way to do this?
  • Jim
Hi @JTWWI ,
When inserting tagging elements on table rows, the recommended approach is to include one additional row that will be left empty. You can then apply small font size to make it practically invisible but you will still have one additional row that you can use if you need to add additional rows. It is a good practice to keep one additional row after you have added additional one.
Adding additional rows when tagging elements are already there might not work every time and it might be cumbersome for some situations.
