In our AX d365fo env ( on premises ) i’m randomly receiving this notification:
Database upgrade from Docentric version 3.3.9.1 to version 3.4.3.1 at 14/04/2023 09:24:30: Error occurred while upgrading DB: System.Reflection.ReflectionTypeLoadException: Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information. at System.Reflection.RuntimeModule.GetTypes(RuntimeModule module) at System.Reflection.Assembly.GetTypes() at Microsoft.Dynamics.Ax.Xpp.DictClass.Getattributedclasses(String attrName) at Dynamics.AX.Application.DocUpgradeManager.fillUpgradeSteps() in xppSource://Source/Docentric AX\AxClass_DocUpgradeManager.xpp:line 27 at Dynamics.AX.Application.DocUpgradeManager.fillUpgradeSteps() at Dynamics.AX.Application.DocUpgradeManager.run() in xppSource://Source/Docentric AX\AxClass_DocUpgradeManager.xpp:line 84Less than a minute ago
It’s the 2nd time now, and I’ve the feeling it’s popping up after a restart of all the aos.
Any hint on what may be the cause/how to fix it, or event how to investigate it further?
According to the notification you sent, I understood that you were upgrading from 3.3.9.1 to 3.4.3.1 but I see that you actually have version 3.4.3.1.
It could be that some artifacts were not installed properly or some upgrade steps were skipped on your side, so I highly recommend you to follow the upgrade steps described in the articles that I mentioned in my previous reply. All of our customers followed the described procedure and they didn’t have problems with the installation/upgrade process.
Please let us know if you have any issues. We are here to help you.
